I am thinking of purchasing Virtual DJ 4.1 but when using the demo I have some files that are in winamp media format. This is what I am using now to play alot of my karaoke files. The karaoke files that I am using that work are in mp3 zip format and they seem to work fine. But all of the files that are listed as winamp media files do not. Is there a setting to correct this? Or is there some sort of conversion I need to do to get them to work correctly? Everytime I use the winamp karaoke files it gives me an error in the window and will not play. Any help you can give me would be greatly appreciated!!!
geposted Mon 23 Oct 06 @ 12:33 am
Yes, you just have to add the extension, and associate a codec with opening it, (default .zip isn't included)
geposted Mon 23 Oct 06 @ 6:05 pm
Check my post on "Solution to Zip Errors..."
geposted Fri 03 Nov 06 @ 7:29 am
