I have the latest version of vdj and mk2 but the headphone channel a or b not work. Do anyone know what to do???
geposted Tue 24 Oct 06 @ 9:26 pm
I'm having the same problem!!
I've been reading for more than an hour and getting nowhere.
input-none
output-single also tried headphones
sound card-Mk2 1-2master 3-4headphones
My set-up is less than a year old and these latest up-dates are really destroying my confidence. It seems like everytime I set-up MK2 I have to fart around with all this config crap! I don't have time nor do I need the stress.
Is there anyone out there??
input-none
geposted Wed 25 Oct 06 @ 4:01 am
tried this one?
input-none
output-phones
first card-your sound device
second card-mk2
firstcard-master
second-headphones?
tried this at a friends vdj who had the same problem and it works fine for him!
input-none
output-phones
second card-mk2
firstcard-master
second-headphones?
geposted Wed 25 Oct 06 @ 12:25 pm
Download the patch. It fixes that:
https://virtualdj.com/update_r2.html
geposted Wed 25 Oct 06 @ 12:50 pm
the patch will not fix the problem i have already that version
geposted Wed 25 Oct 06 @ 12:55 pm
Are you sure you have the latest patch?
Its made purely to fix the headphone (+ a BCD2000 issue).
It should work, and it does at my PC
geposted Wed 25 Oct 06 @ 1:05 pm
yes im shure i try to download updates but i alredy have the latest version...
geposted Wed 25 Oct 06 @ 3:12 pm
I did the download thing too! No fix!!
Did not try Sizzle's fix. Did not even see a first card/second card option. Will try that next.
Someone else posted a change to external mixer in the MK2 software. No fix!!
I have to work Thurs-Sat. I'm running out of time!!
geposted Wed 25 Oct 06 @ 10:10 pm
Saw this post in software forum from moderator Philly DJ
I think it worked!!
https://virtualdj.com/forums/57506/French_Forum/Pr__coute_dans_le_casque_avec_VDJ_pro_4_1___MK2__Solution_temporaire_.html
Try That!!
I think it worked!!
Try That!!
geposted Thu 26 Oct 06 @ 12:37 am
the patch is more for the eq in headphones issue that we were having with the mk2...
dj cel fixed that without the rev2, so that worked out fine..
however, even with the rev2, the sound config has to be like that for the console to work.. dunno why..
PS:there have to be a gazillion threads on the SAME topic..everytime i see mk2 problem, i go to check it out, and eight times out of ten, its this issue...
i request everyone to please search the appropriate forums, because in this most excellent community, problems get solved almost as soon as they come in..so someone else has also had the same issue as you and has probably got it fixed already...
so please.. search the forum instead of just creating new topics at the drop of a hat and save us from multiplicity..
cheers
DJ Rudra
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 4:31 am
The Patch works like a gem.
geposted Fri 27 Oct 06 @ 4:55 am
good to hear
worked a trick for me aslo :)
geposted Fri 27 Oct 06 @ 4:56 am
