(I use the Pio700 skin.)
Suppose I have the following setup in a song :
Cue 1 (First-beat) : 0:00
Cue 2 (Last Chorus) : 3:10
Cue 3 (Break) : 3:30
Suppose I want to add a cuepoint during the first verse, at 2:00. Is there a way to make that "Cue 2", and have the rest of the cuepoints increase by one?
(I like to keep my cuepoints chronological.)
geposted Sat 24 Jul 04 @ 9:13 pm
Hi,
actually it's pretty simple, but be sure you don't mess up all your cue points :o). Here is what you should do :
- load the song (I am sure you knew that one ;))
- don't play it
- go to the cues pannel
- click the "go to cue 3" buttton
- click the "set cue 4" button
- click the "go to cue 2" buttton
- click the "set cue 3" button
So now basically you have moved cues 2&3 to cues 3&4 and you can set a new cue 2.
Of course, you can do the same thing using the cue points keyboard shorcuts.
Hope that helped.
- don't play it
Hope that helped.
geposted Sat 24 Jul 04 @ 9:40 pm
That's possible, but more complicated than what I'd like.
I was hoping for a feature where right-clicking on a "Set" button could move the other cues to the right (and all the names are retained, of course.)
geposted Sun 25 Jul 04 @ 5:52 pm
not possible now, maybe in later versions... its a good idea ;)
geposted Sun 25 Jul 04 @ 6:07 pm
+1 personn for the idea ! I will forward it ;)
geposted Mon 26 Jul 04 @ 5:42 am
ok forwarded.
problem will be how to determine if we need to basically just replace an old cue point, or increase all previous cue points +1 and set a new one ?
geposted Mon 26 Jul 04 @ 5:43 am
Wazmix gave a possible answer : use right click to move all the other cue points, left click to replace.
geposted Mon 26 Jul 04 @ 9:48 am
thats a good way of solving it.... :)
and great that the idea is forwarded ;)
geposted Mon 26 Jul 04 @ 11:52 am
Yes good idea. Seems to be usesul.
geposted Mon 26 Jul 04 @ 3:30 pm
