Hi there,
I called Hercules as I though speed and audio problems were because of them.
They answered me there is no guaranty of interop between MK2 & the V4.1 at the moment and that both companies were currently working out a solution...
So my question is whether anyone has a precise idea when a solution is to be expected ?
Cheers,
Cheers,
geposted Thu 26 Oct 06 @ 9:30 pm
hi creativesound..
what exactly is the problem you are facing?
im sure there is already a soultion, but if we dont know we cant tell you..
cheers
DJ Rudra
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 6:28 am
Hi,
Thanks for answering.
Songs take lots of time to get loaded. The whole thing is like my PC's not powerfull enough to run the system.
Do not have such a problem with the version of the Virtual Dj that comes with the MK2 gear (V2.x).
Hope you can help
Hope you can help
geposted Fri 27 Oct 06 @ 8:41 am
hi..
can you please give us your computer specifications, so that we know that the computer is powerful enough to handle the program..
vdj has come a long way since 2.x and maybe your computer cannot handle it..
also..
take a song, analyse it by right clicking on it and saying analyse..once it has been analysed for the bpm and length, try loading it and see if there is a difference in the loading time..
cheers
DJ Rudra
also..
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 8:58 am
[color=red]Yo
some steps u can take to make your pc performance increase
1. buy some more ram
2. Run Defrags Once a Week
3. try optimisation tools – ie www.iolo.com
4. Lower the performance slider in the main settings , preferences > performance (take it from quality to fast)
5. analize ur entire song collection
6. Put Your music on a separate disk or partition to that of your os
hope that helps :)
Regards
Skyfxl
dj
hope that helps :)
Regards
Skyfxl
dj
geposted Fri 27 Oct 06 @ 11:59 am
Did you install the 4.1r2 update??? This fixx the problems with consoles like mk2 or bcd
geposted Fri 27 Oct 06 @ 12:42 pm
Hi all,
Thks again for the help
Intel P4; 1,5 GHz. RAM : 512Mo
Could of course be better but still should be sufficient I guess. I cannot add more RAM anayway.
Again when using MK2 sound card only, things work fine with VDJ V2. I mean it really works well without any issue
Tho it is more convinient for me to keep my speakers on the internal Sound card. More convinient for recording and better to enjoy the VDJ V4...
Btw, all songs are already analyzed...that's what depresses me ;-)
If u have any ideas...
Thks again
Thks again
geposted Fri 27 Oct 06 @ 12:45 pm
is it a fixed slot ?
you might be able to get more ram it might help
i was on 512 it was a bit slow went up to a gig much faster now
as its the ram thats doing all the legwork
found an interesting optimisation article and posted it here
might help
https://virtualdj.com/forums/58693/General_Discussion/Some_tips_for_speeding_up_computers_for_vdj_or_just_in_general_.html
might help
geposted Fri 27 Oct 06 @ 12:49 pm
