on the hercules you use to be able to have 3 effects assigned to each side. you have changed it where now buttons 1 & 3 are selectors to move cue points, loops and effects. can you please bring back the way it was when you can have 3 effects on each side and when you had the selector set on loops when you hit one, two or there it automatically had set loops? these were fast and easy features that made mixing quick and easy. please respond asap.
geposted Fri 27 Oct 06 @ 2:29 am
i think this is being worked on
try the dj cel mapper from here
http://www.virtualdj.com/addons/tools.html
geposted Fri 27 Oct 06 @ 2:42 am
