Hi im DJsense i have this question about radio djs.. i hear that sometimes djs on the radio are playing a song just the original one, then they go into a different song but this time its a remix... does this mean that when they go from deck A to deck B that deck B has a remix premade by the dj on it or are they actually remixing it at that very moment perhaps having an instrumental on deck B then an acapella as a sample?
and another thing i dont understand is while they are playing the remix the acapella end and then the original acappella for that song on deck B starts... how the hell does this work out? are they using samples? or did they pre-mix then play it
and can you even play a pre-mixed song on the radio? or does everything have to be "live"
geposted Fri 27 Oct 06 @ 4:26 am
hi there
as far as i know it can be a bit of both
ul find out more here :)
http://www.virtualdj.com/forums/36/Virtual_DJ_Radio.html
Regards
Skyfxl
Dj
Regards
Skyfxl
Dj
geposted Fri 27 Oct 06 @ 4:30 am
should i ask in the radio forum?
geposted Fri 27 Oct 06 @ 4:37 am
if u like
try searching first tho u may find ur answer
geposted Fri 27 Oct 06 @ 4:38 am
