Hi,
I have a VDJ setup with TCV vinyl connected via X-fi ASIO drivers. I have my turntable plugged in through the microphone input. Everything is fine, I have 100% signal and running in 1ms latency. However, when i scratch backwards, the track scratches foward instead. I spin my turntable backwards and find that that the track will continue to play fowards. Does anybody know the solution to this problem?
geposted Sat 28 Oct 06 @ 8:46 am
lol are u sure uv pluged the phono cables the right way round ?
geposted Sat 28 Oct 06 @ 11:31 am
Yeah I got em right, red on red, white on white. funny thing is, when I switch it around, the record ONLY plays backward whether I scratch forward or backwards. Does it have to do with the ASIO drivers? I tried options like invert phase or invert stereo but to no avail. My setup looks like this:
geposted Sat 28 Oct 06 @ 7:55 pm
how odd ,
will do some research on this
does any one have any ideas
basic sugestion turn the phono otherway round lol
geposted Sat 28 Oct 06 @ 8:10 pm
yeah it's weird. I'm starting to think it's the X-fi ASIO drivers. But i'm really unfamiliar with how to properly set up the turntable to soundcard line in because there are no official procedures for doing so. I'll try to get it workin the next few days. Will let you know if i get it working.
geposted Sun 29 Oct 06 @ 8:52 pm
hang on , i just realised somthing
ur copy of virtual dj has "limited timecode suport"
u might need to upgrade for this one
geposted Sun 29 Oct 06 @ 9:22 pm
Timecode signal is stereo and your mic input (whats wrong with the line in input ?) is MONO...
You can see this at your graphics. There is only one (red) sine wave/input.
It should be two... The green one is missing...
geposted Mon 30 Oct 06 @ 2:24 am
ah , how could i miss that the shame
its 1 : 30 am here lol
time for bed me thinks
geposted Mon 30 Oct 06 @ 2:29 am
The green wave is actually embedded in the red wave as u can occasionally see green parts.
So I tried messing around with the ASIO drivers and I get this:
Channel 1 and 2 are now fine(forward and backward scratches are good) but channel 3&4 goes haywire. Nothing is plugged into 3&4 and yet I get a bunch of noise in the signal. As a matter of fact, there IS no channel 3 and 4 since there is no input for it. However, whatever noise that comes out on channel 3 and 4 seems to correspond to 1 and 2. Sometimes, the whole program goes hayware and my timecoded vinyl starts controlling the song menu instead. AHH!!
geposted Mon 30 Oct 06 @ 6:01 am
I made a video of this, what you see in the beginning was only the TCV. I did not use the mouse or the keyboard to control the GUI. Deck 1 is corresponding to the TCV as it should, but deck 2 is playing on its own with timecoded noise.
http://www.youtube.com/watch?v=5yEICuAKiUA
geposted Mon 30 Oct 06 @ 6:30 am
heya , 2 steps
one
press autoconfig
two have a read of this
https://virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
one
press autoconfig
geposted Mon 30 Oct 06 @ 11:02 am
I'm not using MK2 drivers, i'm using X-fi ASIO
geposted Tue 31 Oct 06 @ 6:25 am
might be worth trying the mk2 to see what happens?
geposted Tue 31 Oct 06 @ 1:03 pm
yeah i have the mk2 and i've used the setup u posted but it doesn't work well for me. there's too much latency
geposted Tue 31 Oct 06 @ 8:53 pm
try a higher buffer on the asio control pannel
geposted Tue 31 Oct 06 @ 9:35 pm
he got it!
geposted Tue 31 Oct 06 @ 10:02 pm
lol?
geposted Tue 31 Oct 06 @ 10:33 pm
