Upon buying the upgrade I have notice a couple of problems.
First, does not show the playlist that I created in the lower versions.... are the playlists gone or is there a way to bring them in.
2nd - With the upgrade version there is a suggestion folder which has files that I cannot clear
3rd - I have renamed all my files in the VDJ format, but the data base stills brings up the old naming convention with the new.
4th - I still have both the desktop icons for the VDJ lower version and the upgrade version... is this o.k.
5th - I had a problem that I could not get the headphone to work witht the Herculies console... however, that may be my bad, still looking this over.
6th - In order to solve all of the problems above, I was going to remove all VDJ software and only reinstall the lastest version but did not see where I could be able to de install software in the Windows remove software or and exe file to do so as well. How does one remove the software?
Any help would be appreciated.
geposted Mon 30 Oct 06 @ 3:03 am
hi if you have the new setup
simply uninstall
that should solve it
if there is still problems
delete the program folder
and then reinstal
simply uninstall
and then reinstal
geposted Mon 30 Oct 06 @ 11:11 am
