Forum: Old versions
Topic: Recording Mixes to CD audio
2 questions:
If I want to automix mixes to cut to CD is there an easy way to check the length of a mix that a play list will create so it will fit on a CD-R and that the autorecord feature can be set to stop recording onc ethat playlist has finished?
geposted Sun 25 Jul 04 @ 9:55 pm
What's the difference between Version 2.0 and 2.01
