Forum: Old versions
Topic: Sound card problem - Page: 1
manuxioHome userMember since 2006
Hi everybdy,
I am evaluating the latest V-Dj version
and I am experiencing a strange problem
The configuration is with 2 sound cards and one external mixer, so each card is used as a separate channel
The cards are: SBlaster Live! and Realtek AC97, both with latest available drivers
The first card sound great, the second card (in this case, the AC97) sounds creepy and looses bits of sound, plus when, for example I stop the second player I still can hear for a few seconds sounds like "dling, dlang ... ".
As you can imagine, this is VERY annoying and makes it unusable.
Even if I rotate the cards (like, put the AC97 first and Live! second) ... the second one (in this case the Live!) is always creepy.
Looks like, with 2 different models, V-DJ can't handle them correctly.
Can you please send some feedback?
I believe most of you use 2 cards, so I think there must be something strange going on here...
Thank you so much!
geposted Fri 03 Nov 06 @ 9:57 am
sbangsPRO InfinityMember since 2004
try loweing your proformance tab to fast
preferences > proformances
fast < quaility
this should drop the taxation of cpu resources
geposted Fri 03 Nov 06 @ 5:29 pm
It's not a cpu usage issue (nor memory - cpu is always less than 10% and I have 4Gb Ram) ...
and lowering quality does not help much...
Need some more help :(
geposted Sat 04 Nov 06 @ 1:35 am
does the seccond card work as a primary ?
normaly?
geposted Sat 04 Nov 06 @ 2:03 am
both of them, if used as primary work great...
it's always the second card that is 'creepy'...
geposted Sat 04 Nov 06 @ 11:35 am
Just to clear out...
if I only configure one card ... everything is ok (no matter wich one is it..)
With the ac97, I'm also able to use 4.1 configuration smooth (my Live! has no 4.1 capacity...)
it's when I use them both that the trouble come ... no matter wich one is first card ... the second one is creepy
Thank you
geposted Sat 04 Nov 06 @ 12:13 pm
Agree
geposted Sat 04 Nov 06 @ 3:09 pm
Thank you
are they both sending the same hardware interupt , messsage to the processor
irq?
you can check this in device manager
geposted Sat 04 Nov 06 @ 3:20 pm
because if they are it means they are both fighting for each others resources and they both will start to degrade in quality
geposted Sat 04 Nov 06 @ 3:21 pm
geposted Sat 04 Nov 06 @ 3:24 pm
Sorry, but they're on 2 different IRQs....
to me, it seems that V-DJ sets some parameters from the first card (latency?) wich are not fully compatible with the second. Probably my 2 cards are way too different....
Don't know...
Thank you anyway for helping me...
geposted Sat 04 Nov 06 @ 6:29 pm
il keep looking mate :)
see if i can work out any other things to try
geposted Sat 04 Nov 06 @ 6:33 pm
You're very kind :)
I'll keep trying and waiting :)
geposted Sun 05 Nov 06 @ 6:29 am
could you post a picture of your sound setup here
you can use www.tinypic.com
geposted Sun 05 Nov 06 @ 4:47 pm
geposted Tue 07 Nov 06 @ 1:36 am
BoltesHome userMember since 2006
Hey evrybody!
I have the exact same problem. The second sound card simply sounds like crap, however i config it. witch of my cards, latency etc..
I googled for it and ended here...
so...
if you solve it, let med know ;)
geposted Tue 14 Nov 06 @ 11:11 pm
manuxio wrote :
Sorry if I did not reply faster...
Thank you in advance.
http://tinypic.com/view/?pic=42mmqzp
untick
safemode and overclock
and latency to auto and this should solve it for u :)
geposted Tue 14 Nov 06 @ 11:39 pm
Boltes wrote :
Hey evrybody!
so...
please aslo post a screenshot of your sound config using www.tinypic.com
geposted Tue 14 Nov 06 @ 11:41 pm
lets see if i got this right...:
<a href="http://tinypic.com" target="_blank"><img src="http://i10.tinypic.com/2yyzjmo.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
thanx 4 helping out!
geposted Sat 18 Nov 06 @ 12:53 pm
geposted Sat 18 Nov 06 @ 1:14 pm
91%
