IS THERE A WAY TO RAISE THE GAIN LEVEL ON SKINS WITHOUT A GAIN CONTROL(EX. CONSOLE SKIN) PLUS, IN TERMS OF PERFORMANCE IS THERE A DIFERENCE BETWEEN SKINS. THANSKS IN ADVANCE
geposted Mon 26 Jul 04 @ 5:49 pm
Firstly turn caps lock off it makes it harder to read!
Secondly have you tried using keyboard shortcuts to adjust the gain?
geposted Mon 26 Jul 04 @ 10:30 pm
