Forum: Old versions
Topic: error message
i get a error message error in the sound driver of direct X
geposted Sun 05 Nov 06 @ 2:25 pm
phillydjPRO InfinityModeratorMember since 2004
are u starting VDJ without the soundcard u had in the previous config.?
geposted Sun 05 Nov 06 @ 2:41 pm
yes i upgrade it
geposted Sun 05 Nov 06 @ 2:45 pm
if you changed the soundcard you have to go into the Windows sound control panel and make sure that ur new soundcard is the primary one, then go into VDj configs and make sure that ur set to use the new one
geposted Sun 05 Nov 06 @ 2:53 pm
