hi,
I wrote a sound effect plugin which I want to be activated all the time. Now if I reload another track the plugin stops. If has to be re-activated automaticly when I reload a new track.
Any suggestions??
Any suggestions??
geposted Sun 05 Nov 06 @ 7:29 pm
to start aquire software www.virtualdj.com/purchase
this is defualt behaviour i think it cannot be changed sorry
geposted Sun 05 Nov 06 @ 8:00 pm
freak52 wrote :
hi,
Any suggestions??
Any suggestions??
Thats they way the effects work now, alot of users were leaving effects on by accident so it was asked to be like this
That however is just the default setting, your can modify the value in the registry to stay active
might be called clear effect on load
geposted Tue 07 Nov 06 @ 9:47 am
Can tell some more, what must be changed at the registry?
geposted Sun 05 Jul 09 @ 9:16 am
It was added in the config->options of VirtualDJ v6
geposted Mon 06 Jul 09 @ 3:29 pm
Yes I have found it, and it works.
Thank you.
Thank you.
geposted Fri 10 Jul 09 @ 5:40 am
