Can you guys possibly increase the effective resoloution for the DAC-2 Pitch Sliders.
If you use the buttons on screen the increment is 0.1 but by using sliders on DAC-2 it seems to slide for ages then jump about 0.6
I'm used to working with hardware with 0.1 and also if once you complete a mix you want to speed up or slow down a song to it's original tempo it sounds really jumpy and abbrupt.
Thanks.
Thanks.
geposted Tue 27 Jul 04 @ 1:54 am
that might be a limitation of the DAC-2 sliders.
I could be wrong but have noticed that the BPM RCP controllers are much more accurate than the DMC-1 and DAC-2.
WirelessDJ
WirelessDJ
geposted Fri 30 Jul 04 @ 2:02 am
