Just installed V2.01 and i'm the above message when I lauch VDJ.
geposted Tue 27 Jul 04 @ 2:18 am
its because the console/soundcard you used last time, is not connected when u restart VDJ..
Change the the soundcard you are using now, and close VDJ..
restart, and the error message is gone :)
at least was that the case for me
geposted Tue 27 Jul 04 @ 3:11 am
I still get the same message and after I start it up again the database is corrupt. The only time it seems not to crash is when I use advanced config.
geposted Tue 27 Jul 04 @ 11:16 pm
try reinstalling Dx-9 that worked for me
geposted Fri 30 Jul 04 @ 7:05 am
Also rather than reinstalling devices you can open VDJ by going to the root folder and executing the crashguard exe. This will allow you to see the error.....(error in direct x of soundcard) and hit ok. VDJ will now open. You can deselect the usb soundcard that gave you a hassle until you reboot. Also as DJ-In-Norway said unplug and plug back in can solve this.
geposted Fri 30 Jul 04 @ 8:47 am
Install the sound card then change it in the sound config and the card can now be removed without problems.
geposted Tue 03 Aug 04 @ 1:28 pm
