I reainstalled VDJ 3.4 to different folder (not into VirtualDJ as default) and then on DJC Maper doesn't open any more when i start VirtualDJ. Anybody know why?
I need maper and i need 3.4 because of some problems with effects in 4.1.
thanks.
thanks.
geposted Wed 08 Nov 06 @ 11:09 am
hi bud
u tried reinstalling it into the folder?
another tip is if you delete the two ini files with the mapper
and open the mapper again it will create settings and links for the new folder :)
geposted Wed 08 Nov 06 @ 11:28 am
I am talking about DJC maper for version 3.4 not for 4.1. Oldier maper doesn't have ini files and i can't install VDJ into same folder as 4.1.
I am scared to do that. Anybody has 3.4 and 4.1 in same folder? what happened when upgrade?
geposted Wed 08 Nov 06 @ 11:46 am
could you rename 3.4 to virtualdj2.exe?
geposted Wed 08 Nov 06 @ 4:49 pm
Yes, i did it. Now i have booth versions at default folder, but still doesn't work. it works with v4.1.
geposted Wed 08 Nov 06 @ 4:59 pm
There are two files now :
* one for v3.4 and v4.0 (in the main virtualdj folder: djcmapper.dll)
* one for v4.1 with the new SDK for controllers (in the new folder: djc.dll)
geposted Wed 08 Nov 06 @ 7:34 pm
oh that one that is for booth versions works! :D thanks! I didn't know that maper v4.0 is for 3.4 too. Then i tryed and it works!
thanks Cel! ;)
thanks Cel! ;)
geposted Wed 08 Nov 06 @ 11:08 pm
