Ok, I see in the DAC-3 mapper manual that if I hit the Reloop button, it will activate the selected transition. Well, when I try to do so, it only starts the transition and then stops--the transition does not complete itself!
CP + Reloop (temporary transition) works fine, btw...
geposted Wed 08 Nov 06 @ 7:26 pm
RELOOP in video mode simply activates or deactivates the automatic transition feature built into VDJ 4.x - When active, this should automatically crossfade the video based on what you are doing with the two decks (Playing, paused, etc.)
You may like to try the DAC-3 mapper's own built-in automatic video crossfading instead (E.g: SHIFT+PLAY, SHIFT+CUE.) This can also be toggled on for normal presses of PLAY/CUE (Without SHIFT) when in video mode using the R button. Make sure you turn this off though when cueing a track (Same also applies if you use VDJ's automatic transisitions.)
geposted Wed 08 Nov 06 @ 7:53 pm
