Hello,
I had a setup which i had been using for the past three years. Since it was a slow system, and i was getting all kinds of problems (both related and non-related to VirtualDJ), i decided to end this system and build a completely new one, from scratch. I had lots of problems with VirtualDJ 4 + (froze or crashes), which i was hoping will get resolved with my new system.
So, recently, I did a full upgrade to my DJ setup. That includes a Sony Vaio Intel Duo 2ghz laptop with Echo Indigo Dj sound card. I chose this sound card because amongst all sound cards i have used for my studio, Echo Audio has VERY well written drivers for their sound cards.
My problem is (and the reason that i am opening this thread) that today, on my new DJ system, VirtualDJ 4.1 r2 just froze again. Music was playing, and then the graphics suddenly froze, nothing was clickable, DAC-3 froze too, and the only solution was to end the virtualdj.exe process. I am testing the new DJ system for the past 1 week, before i put it to work.
I would really like some response from the developers of the software. My question is:
What can i do to see what caused the froze/crash? Is there an error log? Please help me help you.
I am very sad that i cannot trust 4.1 on a live performance.
Thanx
Al.
Thanx
Al.
geposted Sat 11 Nov 06 @ 1:03 am
to ensure the most stable settings for live work
please lower the proformance tab on the settings page
settings>proformances
fast< quality
towards fast in little jumps until the problems stop
fast< quality
geposted Sat 11 Nov 06 @ 2:16 am
CHECK IRQ SHARING!
geposted Sat 11 Nov 06 @ 2:22 am
ah yes i dint think of that
go to device manager
and u will see it listed under properties for each device
aslo some bios will show u this
geposted Sat 11 Nov 06 @ 2:35 am
Thank you for your responses.
The audio card does INDEED share IRQ with other devices.
However, there's NOT workaround to this on dual-processor machines!
geposted Sat 11 Nov 06 @ 3:09 am
Might want to look at a few of these suggestions for Core 2 Duo systems....
https://virtualdj.com/forums/59367/General_Discussion/Dual_Core_users_(Intel_and_AMD)_-_should_read.html?highlight=core%202
geposted Sat 11 Nov 06 @ 9:05 am
