Forum: Old versions
Topic: Hercules DJ Console 2?
Not sure if any guys from Hercules read these forums, if not, they should.
I've seen in previous posts that there are rumours that Hercules may be making a new controller, if so, they really should look for feedback from the Virtual DJ users as i think there is no doubt that they constitute the majority of the console userbase. I'm sure we all have good ideas on what improvements could be made. It would be a great shame if hercules overlooked us and failed to produce the enhancements we're all looking for.
A few enhancements/modifications i would suggest would be..
- Wider Crossfader
- A little more friction on the crossfader (current is too loose)
- Crossfader not so close to the jog wheels.
- More sensitive & solid buttons (not so rubbery & unresponsive)
- More of a professional look, possibly introduce a low end & high end model (the high end with a more professional build, the low end being a budget model with similar build quality to the present)
what what you guys like to see in DJ Console 2?
geposted Tue 27 Jul 04 @ 10:14 pm
Hercules DOES read this forum, and your ideas are great :)
also, a standard 19" format would be cool, so that some users can use it in a rack :)
