For the first time after 5 years VDJ let me down. I always used my laptop as back to my cds or that quick search for a random request. However i though i should move towards digital djing and bought a dell laptop..1 gig ram..duo processor plenty of stuff...VDJ was working wonderfull, than i purchased m-audio fast track...while playing vdj would stop after three songs, completely. Than I switched back to the old way of hooking up the laptop to the mixer( just off the headphone jack into a channel) That means i could not cue anything but at least it saved me ....My question behind this whole story its basiclly what am i doing wrong? The laptop is updated on all drives, everything that usally runs was turned off. Is it the m-audio fast track pro or is a configuration that i messed up. I selected asio sound card on the configuration. Any help would be appreciated....thank you
geposted Sun 12 Nov 06 @ 8:07 am
check for irq device conflicts on
device manager
go to my computer , right click press properties , then press device manager
then right click devices and press properties and it will tell you
aslo you can do this in bios
or if your not sure about this
there is a free tool
http://www.belarc.com/free_download.html
which will report back to you on devices
device manager
geposted Sun 12 Nov 06 @ 12:27 pm
Since you have a new Core 2 Duo system I would look at some of these performance issues and there solutions -
https://virtualdj.com/forums/59367/General_Discussion/Dual_Core_users_(Intel_and_AMD)_-_should_read.html?highlight=core%202
geposted Sun 12 Nov 06 @ 2:30 pm
geposted Sun 12 Nov 06 @ 3:35 pm
thanks everyone...you think u getting the best quality for your money by adding so much power and speed but in reality thats not the case...Now that i rehooked up everything at home, it seems that yesterday at the gig, vdj was giving me a "Error in the Asio Drive" message before loading....now its not doing that, I also had the primary sound card disabled now i enabled and left it on, but still selected the m-aduio fast track as my soundcard in vdj configuration.... i did a few hours of a test run and everything seems to be going smoothley,,,,thanks for you input, but i defentlty will go ahead and fix the performance based on the websites suggested, thanks a again.....
geposted Sun 12 Nov 06 @ 10:27 pm
glad its ok for u :)
geposted Sun 12 Nov 06 @ 10:37 pm
