What is the configuration/Setup w/ Mk2 if you want to use Mk2 w/ TCV and regular vinyl records??
OOPS TITLE should read TCV (time coded vinyls)
geposted Tue 14 Nov 06 @ 12:44 am
you cant use tcv with home edition
geposted Tue 14 Nov 06 @ 5:20 am
you can use a single timecode
in 3.4 pick single timecode as input
pick mk2 as soundcard
in v4.1r2 follow this guide
https://virtualdj.com/forums/58120/Hardware_Technical_Support/Guide_To_set_up_tcv_with_mk2_console__)_.html
geposted Tue 14 Nov 06 @ 10:30 am
