Forum: Old versions
Topic: BCD2000 sound quality
MehdiocPRO InfinityMember since 2005
Hi,
Heres my set up:
-BCD2000 vdj4 w/ all updates (runs perfect no problems thanks to forum)
- Functions quick fast response no crashes
-Sony Vaio Laptop. Pent. M w/100g harddrive 2g ram
-Wifi set off
-maximum speed setup (followed steps listed in forum)
-Turned off all other usb fucntions
-useing bcd2000 as the external soundcard direct hook up to another external mixer
Im playing one song with my Pioneer CDJ1000 and the sound qaulity was crisp, clear, no hesitation and on beat, then i switched over to my bcd playing the same song (runing BCD threw channel 2 on a external mixer) and noticed that the sound quality was very poor. It sounded as though the song was struggling. To the drunk listener or audiance, they would not even know the differance, but for my purposes, i notice the differance and i find it very difficult to mix from the bcd to any external CD player or vinyl cause several beats are off. All my MP3s are 320K.
An example on a 4 par (1-2-3-4) 1 - 2, would be crisp while 3 would hit late or be slightly lower than 1-2, and 4. maybe a audiance would not When i use B-dj, the software that comes with BDJ, its very clear, but i just hate their program cause it stinks (love VDJ).
Does anyone notice this issue, or am i just to picky.
geposted Tue 14 Nov 06 @ 3:20 am
micha3lHome userMember since 2006
adjust your settings performance
geposted Tue 14 Nov 06 @ 5:31 am
What settings do u suggest. currently its is towards latancy,i followed the setup posted of BCD2000 in the forum. It furthest to the left on latancy.
geposted Tue 14 Nov 06 @ 10:45 am
what about in VDJ... the Performance Settings.. it should all the way to the left too (Fastest)
geposted Tue 14 Nov 06 @ 8:16 pm
Be sure not to use key_lock in low quality settings it causes this !!!
geposted Tue 14 Nov 06 @ 9:55 pm
what kind of sound quality do u expect from behringer?
geposted Wed 15 Nov 06 @ 8:33 am
Are you using asio drivers? if not, change.
geposted Fri 17 Nov 06 @ 4:04 am
djkikePRO InfinityMember since 2004
bcd2000 EQ is not good quality, if you can compare with mk2 you will see... i own both, bcd2000 sound us worst than mk2 or other.
geposted Sun 19 Nov 06 @ 8:58 pm
sbangsPRO InfinityMember since 2004
lower your proformance tab
geposted Sun 19 Nov 06 @ 9:43 pm
