Hope this controller will work with virtualdj. It seems very good
http://www.djdeals.com/vestaxVPC100.htm
Btw, i hope upgrading RAM of my computer (i have 512) to solve problems with maya and hdj consolle.
geposted Tue 14 Nov 06 @ 7:35 am
it is a midi controller so it should work... because you can assign midi withing virtual dj.
hmmm USB tends to use CPU... rather than ram. Ram is great too because windows to run just VDJ is 256 required ram.. add two virtual decks and virtual dj.... plus processing in and out of the sound card and console... might be a great task for it.
geposted Tue 14 Nov 06 @ 9:24 am
yeh that should be fine :)
geposted Tue 14 Nov 06 @ 10:44 am
thanks for double commenting all my posts and agreeing with me lol..... i dont do it to you.... i want vip just as much as you do but you try to hard..... relax a lil.....
geposted Tue 14 Nov 06 @ 3:28 pm
hi everybody...
does anyone have info on the vestax vpc 100 controller..looks good, is it in the market yet, can it scratch, hw expensive (cheap?) is it;....tanx
dj soniq
dj soniq
geposted Sun 31 Dec 06 @ 4:36 pm
