Forum: Old versions
Topic: Headphone Preview on MK2
Hi,
I just got this Hercules MK2 and installed it on my laptop. The headphone preview works fine with the bundled software. My friend has VDJ Pro so I hooked up my MK2 to his laptop to mess around with it and I can't get the headphone preview to work properly with that software. The Mix setting plays the mix and the Split setting plays whatever is playing in one ear, but the Deck A and Deck B selections don't play anything. Everything else seems to be working fine. Is there anything special I need to do to make the MK2 work properly with VDJ Pro?
geposted Sat 18 Nov 06 @ 4:17 am
sbangsPRO InfinityMember since 2004
for pro u need to pick headphone as sound ouput
and select channel 1/2 for master output and 3/4 for headphones
geposted Sat 18 Nov 06 @ 11:59 am
Yeah, that's how I had it setup. I had the output set to Headphones and the Soundcard set to MK2 and the box at the bottom said Master: channel 1/2 Headphones: channel 3/4.
The mix will play on the headphones when the selector is on mix and in the left headphone when the selector is on split, but nothing when the selector is on A or B.
Thanks
geposted Sat 18 Nov 06 @ 4:51 pm
tell your friend to get the latest update..:) fixed now
geposted Sat 18 Nov 06 @ 7:00 pm
ok will do, thanks
geposted Sat 18 Nov 06 @ 7:13 pm
