Forum: Old versions
Topic: Pitching time problem
Hi!
After downloading the ver 1.09 update all the displayed time changes with the pitch. So, if i have like 20 sec left on a track and then slows it down, the time will also slow down instead of recalculating the time...
(Hope you understand my explanation...)
This happens to ALL the displayed time (cuepoints, time to end etc.) except the system time clock...
It's critical that this basic function works because now timing the tracks is really hard and it's really anoying...
Thanx
Fredd
geposted Thu 29 Jul 04 @ 10:18 am
this is all depending on the user who made the skin...
If you try another skin, u might have the result u want :)
also, some skins have a built in feature, where u click on "TIME LEFT", and it will change behaviour to what u are looking for ;)
hope that helps
