Forum: VirtualDJ Plugins
Topic: texzks interverter
hi
this is ment for texzk
hi texzk i think u need to remake the inverter plugin!
cuz there are no sliders or anything!
maybe its something im doing wrong but theres just a box.
please tell me how to use it or remake it please!
geposted Sat 18 Nov 06 @ 8:05 pm
sbangsPRO InfinityMember since 2004
as i specified
it just inverts
the sound and there are no configurable options... ;)
geposted Sat 18 Nov 06 @ 8:08 pm
TexZKPRO InfinityMember since 2005
Hi!
I don't see what I could add, because I never use this plugin...
If you have ideas, please tell them, then I'll see what's possible to do ;)
geposted Sat 18 Nov 06 @ 8:36 pm
yeh but how do i use it texzk?
i mean how do u use your inverter plugin?
geposted Sat 18 Nov 06 @ 8:50 pm
i ment how do i use your inverter cuz wh i click activate nothin happens please tell me!!
geposted Sat 18 Nov 06 @ 9:16 pm
It SEEMS it doesn't work, because it simply inverts the phase of the signal. If you sample something and play it within the same song and the inverter enabled, the equal sounds should be reduced in gain. This happens ONLY if your song is constant in tempo, or you'll just have a flanger, a doubling or other nasty effect. This could be used to extract vocals (or other instruments) fomr a song: you sample a loop where there isn't that instrument and it should be removed. In other words, it will let different sounds play and remove the same.
geposted Sun 19 Nov 06 @ 9:59 pm
it actually works
and it works realy good
i'd like to thank texZK for making this plugin
i use it to make acapella's and/or instrumentals and i use to use acid or other wav editting softwares to do so
but thanx to texZK who made the plugin i requested i can do it on vdj now
i made a video showing how to use this plugin and alot of ppl have msged me about that video
good work texZK and vdj team
heres the link to the video
http://www.virtualdj.com/blog/smokey187/
the video is at the bottom of the page very simple and straight forward
read the blog if u dont get it
peace and let me know what u think
geposted Sat 02 Dec 06 @ 4:19 pm
Thanks Smokey! I'h never thought it could be so useful... It's one of the simplest plugins to do, I had just to invert the sign of each sample...
geposted Mon 04 Dec 06 @ 8:03 pm
u dont know how happy u made me and how much easier my life is
btw no one realy know's the potential of this effect till u see the video this could be a great application for vdj
and thanx again for making the inverter plugin i wasnt sure it was ever gonna happen and i wasnt sure it was gonna work the theory is there but it did
thanx to ur works texz on the effect
geposted Sun 21 Jan 07 @ 5:59 am
Thanks Smokey, I've seen your video on YouTube and I had a shock when I saw my name ;)
It's been so easy to program, but I didn't believe it was so useful, maybe because you MUST have the right timings...
geposted Sun 21 Jan 07 @ 1:12 pm
