Forum: Old versions
Topic: Temporary Goto Cue bug
Hi,
I'm using virtualdj_v4.1r2, and triggering multiple cue points via my midi controller (Oxygen 8). I have the cues set to "Temporary," so I can trigger bits of the song like a sampler:
If the deck is paused, you can trigger from a cue point, and it only plays the song as long as you hold the button down.
I have about 4 cues assigned, each on a different midi key on my keyboard.
BUG: When working with these multiple temporary cues, if you accidentally hold down 2 midi keys at once, the deck snaps out of Pause mode, and into PLAY mode.
I'm assuming this is a bug...am I correct?
Thank you,
-Josh
geposted Sat 18 Nov 06 @ 11:26 pm
