I currently use the Hercules MK2 mixer with the VDJ software that comes with it. I'm looking into a nice pair of turntables but I don't really understand that whole concept. I don't get how the music I've heard DJ's play is digital, but they are records. (sorry, new to the turntables, they may not be records) How does all that work? Cartridges? I have a hard time believing that they use actual records seeing as they'd probably be hard to come by. (again, I'm talking out of my ass here, new to turntables, but not DJing) Thanks for your advice.
geposted Mon 20 Nov 06 @ 1:42 pm
to start please add your serial
http://www.virtualdj.com/fusers/modifuser.html
to get the latest updates
for your mk2
for info on what u can do with virtual dj and turntables look here
http://www.virtualdj.com/products/timecode/
to use this you need to buy the pro edition
http://www.virtualdj.com/purchase/
for your mk2
geposted Mon 20 Nov 06 @ 2:23 pm
Thanks. This is DJ on a Hill. A while back I registered with the VDJ forums and then forgot the login info. I just checked my archives on Outlook Express and found the old info. So I'm going to go and delete the DJ on a Hill account. Unless there's any way to cancel this one and still be able to register the MK2 with the DJ on a Hill account.
Back on topic:
Where it says
"If you want to use two turntables (which is highly recommended), you will obviously need two turntables, but also two line-in inputs on your PC. Be aware that you CAN NOT use the line-in and the mic inputs on the same sound card.
Thus, you'll need either two sound cards or a professional ASIO soundcard having several line-in inputs ."
Can I buy a splitter that turns the one mini-jack into two? You know, like you see people that have it on airplanes when they are sharing a movie.
Back on topic:
Where it says
geposted Tue 21 Nov 06 @ 5:55 am
Do I really need Virtual DJ Pro? I have Virtual DJ 2.0 that came with my MK2. I'd think that would work.
geposted Tue 21 Nov 06 @ 8:49 am
yes you need pro as the copy with home is a limited copy
you could infact use the mk2 as your soundcard for timecode if u want ;)
geposted Tue 21 Nov 06 @ 11:12 am
Ok. I'm considering buying a pair of Stanton T80 Direct Drive turntables. I want to use my MK2 as my mixer, but in order to do that, I need Virtual DJ Professional, correct? So my entire list of things needed should be:
Two Stanton T80's
and
(plus any other accessories I feel I need)
I just want some advice so I don't go and spend all this money only to find that it all won't work together. Thanks for your help.
Two Stanton T80's
and
geposted Wed 22 Nov 06 @ 12:41 am
you can use it as a basic mixer for more info
http://www.virtualdj.com/products/djcedition.html
geposted Wed 22 Nov 06 @ 10:38 am
