when i use the asio4all driver (so i can split the sample track to its own fader)the timecode signal is unstable(from 100% to 0%every few seconds), it makes the songs speed go up and down..when i remove the maya44(the sample sound card) from the asio4all, the m-audio delta44 (the timecode sound card) works better...if i use the delta asio driver it works prfect ,but no longer have a seperate sample out... using vdj 4.1r2 and win xp pro
maya44 usb sound card (ive also tried a soundblaster with the same results)
m-audio delta44 pci sound card
dual amd mp 2800+ cpu's
4 gb ddr ram
so i do not assume it is a cpu lag or ram problem
any ideas?
im missing something here!!!!!
4 gb ddr ram
any ideas?
geposted Mon 20 Nov 06 @ 3:21 pm
