Forum: Old versions
Topic: strange videocard problem
jaakkoPRO InfinityMember since 2006
Hi,
I have a strange problem with my video card. It is nvidia geforce go 7600.
I can play videos seamessly and there is nothing wrong with the sound or video.
BUT, I cannot use any other software (like texteditor, browser, light jockey program etc) than vdj at the same time.
If i minimize vdj skin, and try to do someting on the desktop, when i press mouse button, mouse cursor always jump in the center of the screen?? So i cant click or open anyting on the desktop.
Mouse works perfectly again when i return back to vdj skin. Hmm?
This only happens when
1) I have started vdj
2) I have ticked tv output as nvidia geforce go 600 from the vdj video settings.
It does not happend if i untick video output and play mp3s only.
I just upgraded video drivers to the latest version, but it did not help.....
geposted Mon 20 Nov 06 @ 3:44 pm
cstollPRO InfinityMember since 2004
Do not MAXIMIZE the VDJ Skin.
The mouse jumping to center screen is a bug of the skin being maximized.
geposted Tue 21 Nov 06 @ 12:59 am
Ok, thanks! That helps...
I tried to change resolution to 1024 x 768 from the display settings (which is the size of VMIX skin i use), but it fix the problem
Sometimes when i open vdj, skin just maximizes itself and sometimes not. Maybe I should try to resize VMIX skin to 1278 x 768?
geposted Tue 21 Nov 06 @ 1:08 am
