I need some help. Can anybody help me to tell me which are the right equilizer settings for house and club music. I mean which ranges are really important to modified them. Thanks for your help. I have really no experiance how to set up the equalizer correctly.
Thanks,
Brian Lopez
Thanks,
Brian Lopez
geposted Fri 30 Jul 04 @ 10:55 pm
thats really hard to tell...
depends on the size of the room, placement of speakers, and your own preferences....
as a general rule, making a "U-curve" works great (boost both bass and high..)
geposted Sat 31 Jul 04 @ 1:35 am
if your ear`s are not propper working-forget to be a DJ------------:-(sorry
geposted Sat 31 Jul 04 @ 3:42 pm
how do I install the EQ any one knows thanks
geposted Fri 06 Aug 04 @ 1:55 am
You download the file:
32-Band Equaliser
in your "C:\\Program Files\\VirtualDJ\\Effects\\" directory, and it should appear in the list of effects in VirtualDJ (you have to restart VirtualDJ before it shows up though).
macourteau
32-Band Equaliser
macourteau
geposted Fri 06 Aug 04 @ 2:31 am
