Anyone help
I get a message on starting up that the ''Internal data base is corrupt'' it does not seem to effect playing but when searching it seems to not find everything. Other than that it's just plain annoying !
geposted Sun 26 Nov 06 @ 3:08 pm
search for internal database in the general discussion fourm and you'll find the tool to fix it.
geposted Sun 26 Nov 06 @ 6:23 pm
https://virtualdj.com/addons/download.html?addon_id=2560
try the database repair tool
geposted Sun 26 Nov 06 @ 7:02 pm
And remember to copy your .xml file to another directory outwith the VDJ directory. You will then have two copies, and if the "Internal database is corrupt" message appears again, all you have to do is copy the other version back into the VDJ folder.
Keep spinnin'...(",)
P
P
geposted Sun 26 Nov 06 @ 8:42 pm
