I've been using VDJv2 for ages with my Hercules DJ Console MK1, just got VDJv4.1 and there are loads of problem.
When playing track a, when bringing in a song in on track b, any adjusments to the High/Mid/Low knobs, the crossfader or the pitch, gives a feint distorted rumbeling sound. It kind of sounds liek thunder or a hillcopter in the background.
I've updated all the drivers but it makes no difference.
Any ideas?
Any ideas?
geposted Wed 29 Nov 06 @ 10:51 pm
good luck ... I'm me too for the last two days...
Keep looking and post here
https://virtualdj.com/forums/60578/Hardware_Technical_Support/Hercules_DJ_Console.html
geposted Wed 29 Nov 06 @ 10:55 pm
Any ideas?
Any ideas?
this sounds like an issue with current noise check your computer and cables are grounded
geposted Wed 29 Nov 06 @ 11:04 pm
I found that as soon as I selected master temple the same thing happened to me... I even changed performance down and it still happened.
The controller works perfect if you don’t utilize the sound card..
Witch mapper are you using?
geposted Wed 29 Nov 06 @ 11:59 pm
Not sure, how do I nfind out which mapper I am using?
geposted Fri 01 Dec 06 @ 9:06 pm
As a no license user you aren't using any mapper.
geposted Sat 02 Dec 06 @ 2:14 am
indeed..
geposted Sat 02 Dec 06 @ 11:02 am
