Does anyone else recognise this? When I turn the headphone volume knob on my dj console, I hear noise through my headphones. It stops when I stop turning the knob.
Anyone else has this?
geposted Sat 31 Jul 04 @ 8:54 pm
nope.... but anyway... it may be annoying, but the "crowd" will not hear this
geposted Sun 01 Aug 04 @ 2:25 am
i recognise it, but it is only doing that when you are not playing a song
so it doesn't bother me at all
geposted Sun 01 Aug 04 @ 9:46 am
Same problem here. But does NOT affect on output.
geposted Mon 02 Aug 04 @ 7:02 am
I have noise when VDJ is in advanced mode (during a song). when I play songs in the simple mode, then there is no noise.
the same problem on another computer...strange!
geposted Wed 04 Aug 04 @ 8:13 pm
Nothing to worry about. This noise is caused by 'dust' in the pot... a common problem with cheaper electrical components. As has been said, this won't transfer to the output signal. You _could_ fix it if you wanted by replacing the existing pot with a more professional standard component, but its really nothing to worry about.
geposted Fri 06 Aug 04 @ 11:46 am
