Hello
how can I configure vdj/cue so that by using the scratch wheel on a xp10 I can control an independent audio and video file with the same movement. i.e. I want to scratch an mp3 and simultaneousley control a seperate, mute video with the same actions.
BTW my copy of cue is in the post because a guy at numark convinced me it is possible- however after playing with the demo I can't figure out a way of doing it.
Thanks for your help
geposted Fri 01 Dec 06 @ 3:43 pm
try the built in xp10 mapper to assign commands to buttons :)
geposted Fri 01 Dec 06 @ 5:15 pm
but button mapping and the xp10 aside, how do you actually configure one of the virtual decks to control a different mp3 and mov file? When I drag either one onto the deck it controlls each independently, but how do I make it control both simultaneously? Or can it only conrol one source file at a time?
geposted Fri 01 Dec 06 @ 8:20 pm
xp10 , can control A or B
u choose which one :)
geposted Fri 01 Dec 06 @ 8:34 pm
Thanks for your help but I still don't think you understand my question. Simply put, how do I control A AND B simultaneously with the same deck?
geposted Sat 02 Dec 06 @ 3:46 pm
im not sure if you can
"One or two controllers ?
VirutalDJ can be used with either one or two remotes.
If you only buy one, the Switch button will let you change the active desk on which the remote's operations will be applied.
And of course, if you buy two remotes, each one will control its own desk.
Plug each remote's audio into one channel of your mixtable, and your system will look quite the same as a traditional DJ CD player set (but with so many more powerful features).
geposted Sat 02 Dec 06 @ 4:24 pm
