Forum: VirtualDJ Plugins
Topic: Karaoke on virtual Dj
Just bought the Dj Control Mp3 from Hercules with the virtual Dj Software. Is it possible to have a plugin to use cdg karaoke files and mix them together for using on a karaoke happening for example.
thx for any reply
Gino
geposted Sun 03 Dec 06 @ 3:50 pm
sbangsPRO InfinityMember since 2004
yes but not in fullscreen
for this u need pro
geposted Sun 03 Dec 06 @ 4:02 pm
Ok I have PRO .how do i get it to down load CDGs and then how do i send them to a dif screen .for play back.Thanks Mack
geposted Wed 10 Jan 07 @ 7:20 am
you should be able to just load the .cdg file. as long as it has a matching audio file with exactly the same file name.
geposted Wed 10 Jan 07 @ 12:06 pm
