Forum: Old versions
Topic: soundcard configuration on ver 2.01
Probably, i'm just the only one but......
there was a VERY usefull option on the last version i haven't found on that new one!
Why or where you can configure every single channel to a different output from the soft to the soundcard?
geposted Sun 01 Aug 04 @ 10:49 am
its still there... just a bit more "hidden" in the new easy to use interface.
Look for advanced settings :) it's the second last image if you scroll down in soundcards setting
hope that helps
thank you very much!
Silly me!!!!!
now, everything s just FINE!!!!!!
thanks again norway!
no problem ;) just glad to help
can you tell me how to enter ADVANCE CONFIGURATION MENU?Where is the tab?
It can't work in a cracked version.
deja-vu all over again...
