Topic: Smoother Transition?
Any chance that there can be a smoother transition...let's call it a "blend" between two songs. This is especially problimatic if you want to let VDJ do things automatically with a song that does not have a strong beat at the end or beginning of the song.
I'm looking for something that just blends that last 5 seconds of the actual file with the beg 5 seconds of the next file.
Please let me know if there is any way to do this....sounds simple (winamp can do it, iTunes can do it) but VDJ doesn't do it. What gives?
SwingShoes
geposted Mon 04 Dec 06 @ 10:22 am
automix will do this
if u set the fade lengh for 5 seconds and force fade if thats what u mean
No...that won't do it. That will only fade from the 5 seconds before the last beat of music...not from 5 seconds before the end of the song/file.
Anyone else have a solution??
The last 5 sec of the file, could contain 1 beat or nothing. Same with the first 5 sec. Try taking the auto cue off, and see if that works for you. Also, shorten the fade length to your preference.
