i just my icdx and the display srceen is not show any help
geposted Tue 05 Dec 06 @ 4:14 pm
could you explain what u mean a bit more for us thanks
geposted Tue 05 Dec 06 @ 4:56 pm
i power it up and there is nothing on the screen so i put a cd in and i cant get it out and i change change the source in order to use vdj i think the device is defected i might send it back if the problem is not solve by tomarrow
geposted Tue 05 Dec 06 @ 5:01 pm
call their support sounds like a dead unit
aslo check the fuse
aslo check the fuse
geposted Tue 05 Dec 06 @ 10:51 pm
