I was wondering if it would be possible to use the jogwheels to control loop lengths on the BCD2000, or any other controller. What I had in mind was holding down or pressing one of the unassigned buttons (eg talkover) to select the loop mode, then either increasing or decreasing the length using the jog. This could also be made to work with either deck, so the left jog controls length and the right jog controls the shift on the active deck.
Does anyone know whether this would be possible, and if so would somebody either instruct me how to make it or make the plugin themselves?
geposted Thu 07 Dec 06 @ 7:11 am
@antonyingham
it's possible writing a mapper that's is a special dll to re-assing and programming functions keys....
you can download a mapper in the external tools section.
http://www.virtualdj.com/addons/view.html?type=tool
This mapper has not exatly the function that you want...but you can control that function in other way...see the pdf manual to understand how!!
Before start other modify and release of the mapper i need to understant the most common request....
geposted Thu 07 Dec 06 @ 8:53 am
