Forum: Old versions
Topic: is there a hidden folder 4 vdj
i was wondering if there was a folder that saves all your cue points. i would like to copy it and put it on another hard drive so i dont have to set it up for every hd i have. thanks
geposted Thu 07 Dec 06 @ 7:17 am
sbangsPRO InfinityMember since 2004
copy virtualdjdatabase.xml
mp3databse.txt
virtualdjdatabase(yourusername).xml
remember to rename the last file to the username ur using at the time ;)
geposted Thu 07 Dec 06 @ 11:24 am
What exactly does the mp3database file contain, I never save it or transfer it from HD to HD (and I have 4 of them). But I always move the virtualdatabase.xml around all the time.
geposted Thu 07 Dec 06 @ 5:32 pm
a list of where the files are
once its copied press recurse
geposted Thu 07 Dec 06 @ 6:21 pm
Sky, correct me please if I'm wrong. Wouldn't this only apply if the HD you hook up to the "Other"
computer registers at the same drive letter? I have one computer that always puts the first HD in at F,
The other computer puts it at E???
geposted Thu 07 Dec 06 @ 6:57 pm
well say 2 pcs show it as F
and one as E
just press recurse on the search page
and all fixed
geposted Thu 07 Dec 06 @ 7:12 pm
