I just scanned my HD to get my songs from my C drive to the Local DB. It seems VDJ moved all my files and are now GONE from my C drive.
are these placed in a VDJ folder somewhere .. years of music gone !!@ help
geposted Fri 08 Dec 06 @ 5:24 am
When scanning the HD to build the database VJ only reads the files. It doesn't move anything.
Sorry, but it can't happen as you describe it....
geposted Fri 08 Dec 06 @ 5:26 am
sounds like you may have a failing harddrive
as as cstoll says its impossible as vdj cant move files
geposted Fri 08 Dec 06 @ 1:24 pm
Well this is what exactly happened.
I did scan local HD
it listed all my tracks in the Local DB file folder in VDJ
I didnt like how they were no longer in folders
So I selected all and deleted
VDJ sent all files in the local DB to my recycle folder
I went into my recylce bin and 5000+ songs were there . I was scared
So immediately I selected all and hit restore all file
But they were NO longer in the folders on my C drive
They were still in the local DB but now said error when playing or could not find
I did a re-scan and the files were not there
I just dont know .. luckily I have all my vinyl and song up to summer on DVD but still $$ and time gone
I guess im an isolated case/
Love VDJ .. but will never use HD scan - until I know what happend
I did scan local HD
geposted Fri 08 Dec 06 @ 5:22 pm
mate sounds like u have a serious windows problem there
geposted Fri 08 Dec 06 @ 6:36 pm
It is because you selected the files and told VDJ to DELETE them.
If you want to clear the database next time. Right click on the 'Local Database' in the left nav panel, and choose 'Delete' that way. That method only clears the database file.
What you did was told VDJ to delete the files - no delete the database.
Schooling --
VDJ database is a running list. It will not display the tracks in folders.
If you want to see your stuff in a folder method, you must make those folders 'Favorites'
Read the User guide - it will explain and it is very easy.
https://virtualdj.com/support/VirtualDJ%204%20-%20User%20Guide.pdf
pages 7 & 8
Schooling --
pages 7 & 8
geposted Fri 08 Dec 06 @ 6:39 pm
Doesn't know how to use the program, that's the problem. Your eyes are getting crossed even further.
geposted Fri 08 Dec 06 @ 6:40 pm
true but if u press restore in recycle bin and it all vanishes not a good sign lol
geposted Fri 08 Dec 06 @ 7:20 pm
true
geposted Fri 08 Dec 06 @ 7:56 pm
http://www.drivehealth.com/
try this ;)
try this ;)
geposted Fri 08 Dec 06 @ 8:36 pm
thx all .. this is a huge help .. its seems its a bit of both .. lack of knowlege of the program and windows
you all been very helpful .. especially the tip about the delete
xtc
xtc
geposted Sat 09 Dec 06 @ 1:19 am
good luck!
geposted Sat 09 Dec 06 @ 9:05 pm
