Anybody can help me on how to configure master tempo manually on v4.1r2? what are each setting for?
thnx
thnx
geposted Sun 10 Dec 06 @ 2:27 am
this is now called keylock use the padlock symbol to activate or deactivate
geposted Sun 10 Dec 06 @ 2:31 pm
I know, but a t config menu there's also option to config manually.
Any idea on how to configure advanced setting? what to set at Complexity or spatialization?
geposted Mon 11 Dec 06 @ 1:52 pm
Complexity:
quality to use for the mastertempo when it is activated.
0 uses the old 3.x algorithm
1 is the new high quality
2 is super high quality
3 is hyper high quality (you'd better have a double-core in order to use it)
Spatialization
parameter that let you defines time-accuracy toward quality.
0 use the default
1 is very spatialized
5 is very global.
Don't set a value higher than 0 for spatialization if you have a low computer. If your computer can support it, the best settings are {3,1}
Spatialization
0 use the default
5 is very global.
geposted Mon 11 Dec 06 @ 3:30 pm
thanks Cel, i couldn't find this at the manual
geposted Tue 12 Dec 06 @ 7:47 am
