Forum: Old versions
Topic: plug ins cause crackles
markdPRO InfinityMember since 2003
I am using a dell laptop 1.6 ghz with 512mb of memory. It works fine until i use the plugins in vdj, as soon as i press one vdj starts to crackle and freeze up. How can i fix this?
geposted Mon 11 Dec 06 @ 5:34 pm
sbangsPRO InfinityMember since 2004
have you tried lowering your proformance tab?
geposted Mon 11 Dec 06 @ 6:49 pm
djcelPRO InfinityModeratorMember since 2004
Some of the plugins of Deun Deun can make a big noise if you use them with other plugins (at the same time) but the other ones should work.
geposted Mon 11 Dec 06 @ 7:06 pm
where would i lower my preformance tab? Do I have suffient memory to run vd with plugsj?
geposted Mon 11 Dec 06 @ 7:51 pm
lower your proformance tab
geposted Mon 11 Dec 06 @ 7:54 pm
512 is good but you may wish to get more if you can it will boost speed and proformance
geposted Mon 11 Dec 06 @ 7:55 pm
