Any chance of having this list reversed so it starts with the song you first played?
geposted Wed 13 Dec 06 @ 8:09 pm
sadly im not sure this is currently possible?
geposted Wed 13 Dec 06 @ 9:47 pm
When you close VDJ it creates a playlist for that session. The playlist is in the start to finish order of your session - which is your 'history'. Look at your playlists.
So, yes it is done for you... date stamped playlist
BTW which history are you looking at? Event the history.txt is in the order in which you played the files.
geposted Thu 14 Dec 06 @ 1:27 am
Well that must mean my copy is broken ;) the one i use is on the info page of the config window
geposted Thu 14 Dec 06 @ 10:37 am
That is a button/feature you can use, however if you look in your left navigation panel, you will see a playlist folder. Click the + do you see a list of files with dates? Click on one. This is the playlist for that date with the tracks in the order you played them.
Now, if you are not seeing any files under playlist then we can resolve that glitch...
geposted Fri 15 Dec 06 @ 3:22 am
Thing is that the txt file is more useful to me cos i can then put it straight into my CD wallet designer app.
Though thanks for the tip onthe playlists.
geposted Sun 17 Dec 06 @ 3:04 pm
