Hi when I upgraded from 3.4 to 4.x all my previous playlists i.e. the log of all the previous gigs I have done has suddenly dissapeared?
Is there a way to re-activate this feature?
thanks in advance
thanks in advance
geposted Fri 15 Dec 06 @ 4:23 pm
did you back up your database?
geposted Fri 15 Dec 06 @ 4:50 pm
Read this post --- it's a common upgrade problem
https://virtualdj.com/forums/60616/Software_Technical_Support/AutoSave_Session_Playlist_is_not_working.html?highlight=playlist%20and%20database
geposted Fri 15 Dec 06 @ 4:51 pm
Use Dj Cels Registry Tool:
https://virtualdj.com/addons/download.html?addon_id=2170
Enable autosave.
And you playlists will be saved in the playlist folder.
Add this folder as favorite in VDJ, and you have it back like 3.4
geposted Fri 15 Dec 06 @ 5:25 pm
