well i have this problem. every time after (about 20 seconds) music is still playing but the video stops. please help me couse I've tried everything. Someone said that it's a problem of core duo processor's - is it true? i have one. I've even to lock program under one cpu coalition but the problem remains :( My graphic card is Gforce 7400, i have 2GB of memory DDR2. please tell me what should I do?
geposted Fri 15 Dec 06 @ 6:16 pm
try to lower your proformance tab:)
geposted Fri 15 Dec 06 @ 9:07 pm
I've tryed almost everything but the problem remains :(. but there is one thing I did tonite. I've installed and run VDj on my old Pc (it has 900 Mghz Cpu) its very old and guess what? there was no problem. Does It mean that this program doesn't work on Core Duo processors ?
geposted Sat 16 Dec 06 @ 4:39 am
try searching the forum for advice for dual core users
have u got any device conflicts ?
https://virtualdj.com/forums/60644/Hardware_Technical_Support/_HW_How_to_solve__issues_with_bad_sound__unstable_devices__pops_and_crackles_.html?highlight=advice
geposted Sat 16 Dec 06 @ 1:04 pm
hi sky
i've tried. I found few posts of people having some problems but mostly their problems are diferent and there are not many post that might help me.
Have you got Core duo processor ? have you got simmilar problem? did You solve it? please help me
geposted Sat 16 Dec 06 @ 2:37 pm
I FOUND A SOLUTION ! Hardware aceleration must be disabled !!! but right now the video efects does not work. anyone can help ?
geposted Sat 16 Dec 06 @ 5:41 pm
could you tell me the model number of your video card :)?
Gforce 7400
usualy 10 digits
on the manual see if i can drag up some techy info
Gforce 7400
usualy 10 digits
geposted Sat 16 Dec 06 @ 6:14 pm
Im sory I made a mistake with writing specs of pc parts. the Gforce 7400 is in configuration of notebook I wish to buy. I was testing it if it will handle this program.
this is its configuration:
Opis Produktu
HP Pavilion dv6100 Intel Core Duo T2050 1,6 GHz FSB: 533 MHz 2 MB Hyperthreading Centrino Duo 512 MB SODIMM DDR2 NVIDIA GeForce Go 7400 128 MB Karta dźwiękowa: Sound Blaster Pro compatibile
and my own pc has Nvidia GeForce 6200 TurboCashe(tm) with 64mb memory.
I can't find manual so i hope this info will be helpful for you.
thx for interesting in my case.
Opis Produktu
geposted Sun 17 Dec 06 @ 4:44 am
64mb memory. is reali low mate
im not sure if this will be enough for a steady video
geposted Sun 17 Dec 06 @ 12:03 pm
try this to free up some ram and cpu
geposted Sun 17 Dec 06 @ 12:04 pm
i did that - but there is only one question.
after disableing hardware aceleration video effects and video transition is not working on every 4 types of computer i was testing it.
what should I do to disable it byt save these efects ?
geposted Mon 18 Dec 06 @ 9:19 pm
Sorry man if you disable hardware acceleration you can't use the effects.
geposted Sun 24 Dec 06 @ 5:51 am
yes do you know the full model number for your video card il try and bring up some techy info on it :)
geposted Sun 24 Dec 06 @ 1:57 pm
Hi.
on the video card is a sticker with some digits.i hope it wil help you.
EN6200TC256/TD/64M/A
5AC0AB056022
i hope it will tell you somethin'
mary x mass ;]
5AC0AB056022
mary x mass ;]
geposted Tue 26 Dec 06 @ 8:16 pm
do you have the latest direct x and drivers?
geposted Tue 26 Dec 06 @ 8:34 pm
yes i have bought. latest drivers and DX.
maybe it's becouse of the system - i wark on Xp Home Edytion. maybe Pro Version will be better. Will it change anythin' ?
geposted Tue 26 Dec 06 @ 11:02 pm
i think the graphics cards to small to video mix sorry
changing your os wont boost it :(
could try a ram upgrade aslo
geposted Tue 26 Dec 06 @ 11:29 pm
