When I recorded my mix it had both decks playing in the same time all along, complete mess.
I have got two usb-s connected, and recorded from Master, if I try to record from Line in it gives a continouos noise from speakers.
I would need a complete setup guide with all the details from vdj, and the numark dmx, too.
Thank You
Krisz
Thank You
Krisz
geposted Sat 16 Dec 06 @ 8:42 pm
could you post more info on your soundcards
and pc spec?
and pc spec?
geposted Sat 16 Dec 06 @ 8:50 pm
well, the numark has two usb audio codec sound cards, plus the one in the laptop, I also have an external soundblaster but I dont use it with.
geposted Sat 16 Dec 06 @ 10:18 pm
alrighty what u trying to record :)
geposted Sat 16 Dec 06 @ 10:45 pm
The music I mix on the numark in mp3, and that I can hear out from the two speakers ( the master). Before I used only the laptop and vdj itself without external mixer, and recorded with it, and everything was fine.
geposted Sat 16 Dec 06 @ 11:31 pm
choose line in record mode :)
geposted Sat 16 Dec 06 @ 11:59 pm
when I do that it makes a continuous electrical noise in the speakers.
geposted Sun 17 Dec 06 @ 3:27 am
ic
check ur groundings
check ur groundings
geposted Sun 17 Dec 06 @ 3:45 am
I did. still the same. It only start making the noise as soos as I start recording.
It does only in Line in, and Master+mic recording mode.
geposted Sun 17 Dec 06 @ 5:10 pm
could you post for me a screenshot of your config
using www.tinypic.com
geposted Sun 17 Dec 06 @ 6:04 pm
geposted Sun 17 Dec 06 @ 9:13 pm
