Forum: Old versions
Topic: dxm09 mixer and herc mk2 question
aubs123PRO InfinityMember since 2006
hi all
i am thinking of getting the numark dxm09 to use as a ext mixer with my herc mk2 as just the controller
i like the idea of being able to use the third chanell for the vert dj sampler as well
my question is if was useing the fx on the dxm09 like flanger tape echo etc would i be able to still record my mixes with the effects from dxm09 still comeing through to the mix if so how would i conect it up to do so
have read verious posts on the forum but still a bit confused on whether it can be done or not
any help would be much apriciated if it can be as i would like to get one
thanks aubs
geposted Sun 17 Dec 06 @ 2:18 pm
trez777Home userMember since 2006
yeah you should be able to do that. im not sure if the dmx09 has a record or booth out line but just get the master out into the line-in of your mk2, then record from vdj.
geposted Sun 17 Dec 06 @ 2:35 pm
sbangsPRO InfinityMember since 2004
enable external mixer mode on mk2
console
take the master out of your external mixer into your internal soundcards line in :)
geposted Sun 17 Dec 06 @ 2:45 pm
thank you guys for the info
if i can make to the store for 3pm i can get one today if not il pick one up tomorrow
chears aubs
geposted Sun 17 Dec 06 @ 2:51 pm
:) goodluck
geposted Sun 17 Dec 06 @ 2:58 pm
DJKosmoPRO InfinityMember since 2006
Skyfx,
Is it ok to connect the external mixer to my mk2 without using turntables?
I tried this last night with my Ueri 1601s and it sounded like crap
I have the console verson of VDJ that came with my MK2
where is the setting for external mixer?
Thanks
geposted Thu 28 Dec 06 @ 12:17 pm
you may need to upgrade to pro for this ,
i will check
geposted Thu 28 Dec 06 @ 1:23 pm
