Okay I have vdj 3.0... I bought some turntables and I want to be able to configure it with vdj so I can expand my music since I'm only limited to just vinyls. What do I need? Cables? What else?!!? Any help will be appriciated!
Thanks!
Thanks!
geposted Tue 19 Dec 06 @ 4:01 am
well for starters,
https://virtualdj.com/perchase, or enter your cerial and u ned a soundcard such as u46 dj, altho i dont think they will be making them much longer, so if u wanna use time coded vinyls with vdj, u better get your hands on a u46 dj quik, hope that helps!
geposted Tue 19 Dec 06 @ 4:59 am
oops, dont thnk that link went anyware here, https://virtualdj.com/purchase/ that link is to buy the software, click on the second link, cuz the first one didnt go noware, hope thats helps, or if u baught the software enter your cerial, one of u guys post the link to enter your cerial, i cant find at the moment, hope that helps!!
geposted Tue 19 Dec 06 @ 5:04 am
I already have vdj.. 3.0 version... Explain mroe than just I need a soundcard. And any link on how to set it up and such?? I'm going to go t guitar center and talk to a rep and see if he can help me out
geposted Tue 19 Dec 06 @ 7:17 am
djrec01,
You are in possession of a non current version and do not appear to be a licensed user.
We do not support crack users in this forum.
If by chance you are a registered user you need to contact eservice to iron out the problem.
Thank you
mp3jrick
Virtual DJ Support Team
Thank you
mp3jrick
geposted Tue 19 Dec 06 @ 1:25 pm
